跳转到主内容
Lenovo Yoga 710-14IKB SSD Replacement
你所需要的
  1. Lenovo Yoga 710-14IKB SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB SSD Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 710-14IKB SSD Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 710-14IKB SSD Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB SSD Replacement, SSD: 步骤 3 中的图像 1,2 Lenovo Yoga 710-14IKB SSD Replacement, SSD: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  4. Lenovo Yoga 710-14IKB SSD Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 710-14IKB SSD Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
结论
7等其他人完成本指南。
Grant Doerksen
于04/17/17注册
1,005 声望
创作了5篇指南
团队
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G5
4 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 71
总计 11,449
