跳转到主内容
Lenovo Yoga 710-14IKB Headphone Jack Replacement
你所需要的
  1. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 1,1
    • Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Make sure not to strip the screws as they can sometimes be hard to remove.
  7. Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Disconnect the wire.
    • Be careful not to pull or yank the cable.
  8. Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Remove the headphone jack circuitboard.
结论
Evan Cruzen
于11/01/18注册
253 声望
创作了2篇指南
团队
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 616
