跳转到主内容
Lenovo Yoga 710-14IKB Fan Replacement
你所需要的
  1. Lenovo Yoga 710-14IKB Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Fan Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 710-14IKB Fan Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 710-14IKB Fan Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Fan Replacement, Fan: 步骤 3 中的图像 1,2 Lenovo Yoga 710-14IKB Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Unscrew the the two 4mm Phillips #00 screws holding the fan in place.
    • Be careful not to break the thin plastic tabs on the fan casing.
  4. Lenovo Yoga 710-14IKB Fan Replacement: 步骤 4 中的图像 1,2 Lenovo Yoga 710-14IKB Fan Replacement: 步骤 4 中的图像 2,2
    • Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board.
    • Slide it straight out of its socket.
  5. Lenovo Yoga 710-14IKB Fan Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 710-14IKB Fan Replacement: 步骤 5 中的图像 2,2
    • Lift the fan up and out of its mount.
    • Be careful that the small plastic tabs don't get snagged on any other parts or cables.
结论
2等其他人完成本指南。
Grant Doerksen
于04/17/17注册
1,005 声望
创作了5篇指南
团队
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G5
4 名成员
创作了27篇指南
4条评论
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
k.kubaitis - 回复
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
David Hansson - 回复
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
edwardrmorley -
does anyone know the best place to buy a new one of these fans?
edwardrmorley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 3,434
