跳转到主内容
Lenovo Yoga 700-11ISK Solid State Drive Replacement
你所需要的
  1. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 1,1
    • Remove the one 2mm Phillips #1 screw holding the hard drive to the laptop.
  6. Lenovo Yoga 700-11ISK Solid State Drive Replacement: 步骤 6 中的图像 1,1
    • Pull the solid state disk out of the connector and lift it out of the laptop.
    • Make sure the hard drive is oriented correctly with the label facing up before re-inserting.
结论
8等其他人完成本指南。
Emma Morley
于10/23/16注册
378 声望
创作了2篇指南
团队
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G6
4 名成员
创作了7篇指南
3条评论
How to transfer the windows os to the newly install Crucial ssd?
Bernardino Santiago - 回复
how to transfer the windows OS to the newly install ssd?
Specification for the M.2 SSD: Make sure it’s a Type 2280 (22mm x 80mm) SATA M.2 with B and M key edge connector, not the B key used on NvMe M.2 for PCIe. It’s easy to confuse the two when ordering online.
Joe Rhio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 5,248
