跳转到主内容
Lenovo Yoga 700-11ISK Power Port Replacement
你所需要的
  1. Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 700-11ISK Power Port Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Power Port Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Power Port Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Power Port Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: 步骤 5 中的图像 1,2 Lenovo Yoga 700-11ISK Power Port Replacement, Power Port: 步骤 5 中的图像 2,2
    • Remove the following screws holding both the right LCD hinge and the power port to the laptop:
    • Four 5mm Phillips #1 screws.
    • One 3mm Phillips #1 screw.
    • Gently pull the hinge up and away from the laptop.
  6. Lenovo Yoga 700-11ISK Power Port Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 700-11ISK Power Port Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 700-11ISK Power Port Replacement: 步骤 6 中的图像 3,3
    • Carefully slide bundle cable connector out from its connector on the motherboard.
    • Pull the ends of the black connector containing the wires to avoid damage to the wires.
结论
3等其他人完成本指南。
Emma Morley
于10/23/16注册
378 声望
创作了2篇指南
团队
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G6
4 名成员
创作了7篇指南
2条评论
Hey
I own lenovo yoga 700 14 inch, it has a motherboard 5b20k41654. For some reason two of mother board ics burnt out
I have got the number of one IC but failed to find the number/code of other. (the IC I am looking for resides near left side of ram slot)
Please let me know if someone can help me finding the right IC or Schematic of yoga 700 motherboard
I'll be very great full
Thanks
muhammad bilal - 回复
If you’re replacing the power port where is the part? How do I find the power port to replace? Which part is it?
atom_burke - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 5,535
