跳转到主内容
Lenovo Yoga 700-11ISK Battery Replacement
你所需要的
  1. Lenovo Yoga 700-11ISK Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Yoga 700-11ISK Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Battery Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
结论
7等其他人完成本指南。
Sean Wong
于10/06/16注册
859 声望
创作了3篇指南
团队
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G6
4 名成员
创作了7篇指南
3条评论
Hey
I own lenovo yoga 700 14 inch, it has a motherboard 5b20k41654. For some reason two of mother board ics burnt out
I have got the number of one IC but failed to find the number/code of other. (the IC I am looking for resides near left side of ram slot)
Please let me know if someone can help me finding the right IC or Schematic of yoga 700 motherboard
I'll be very great full
Thanks
muhammad bilal - 回复
Why do you recommend buying a T7 Torx Screwdriver? I bought it, then re-read your tutorial after I couldn't unscrew the screws, where you said it should be a T5 Torx Screwdriver...
Eric Macaluso - 回复
Charging point break not display
Lenovo laptop notebook 6 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 35
总计 8,577
