跳转到主内容
Lenovo Yoga 3 Pro USB Ports Replacement
你所需要的
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: 步骤 1 中的图像 1,1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 3 中的图像 1,1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 4 中的图像 1,1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 6 中的图像 1,1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: 步骤 7 中的图像 1,1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 9 中的图像 1,3 Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 9 中的图像 2,3 Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 9 中的图像 3,3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 10 中的图像 2,2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 11 中的图像 1,2 Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 11 中的图像 2,2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: 步骤 12 中的图像 1,2 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
  13. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 13 中的图像 1,1
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
  14. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 14 中的图像 1,1
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
  15. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 15 中的图像 1,1
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
  16. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 16 中的图像 1,1
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
  17. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 17 中的图像 1,1
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
  18. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 18 中的图像 1,1
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
  19. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 19 中的图像 1,1
    • Remove the USB assembly using the plastic opening tool.
  20. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 20 中的图像 1,1
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
  21. Lenovo Yoga 3 Pro USB Ports Replacement: 步骤 21 中的图像 1,1
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
结论
10等其他人完成本指南。
团队
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G17
4 名成员
创作了15篇指南
4条评论
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - 回复
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - 回复
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - 回复
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 47
总计 13,338
