跳转到主内容
Lenovo Yoga 3 Pro Speakers Replacement
你所需要的
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 6 中的图像 1,1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: 步骤 7 中的图像 1,1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 8 中的图像 1,2 Lenovo Yoga 3 Pro Speakers Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 9 中的图像 1,3 Lenovo Yoga 3 Pro Speakers Replacement: 步骤 9 中的图像 2,3 Lenovo Yoga 3 Pro Speakers Replacement: 步骤 9 中的图像 3,3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga 3 Pro Speakers Replacement: 步骤 10 中的图像 2,2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: 步骤 11 中的图像 1,2 Lenovo Yoga 3 Pro Speakers Replacement: 步骤 11 中的图像 2,2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G17
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 2,745
