跳转到主内容
Lenovo Yoga 2 Pro Wireless Card Replacement
你所需要的
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 1,1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 Pro Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Slide the wireless module towards the battery and lift out of the laptop.
结论
9等其他人完成本指南。
Thomas Simko
于10/01/15注册
2,511 声望
创作了5篇指南
团队
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G14
5 名成员
创作了12篇指南
2条评论
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 43
总计 11,198
