跳转到主内容
Lenovo Yoga 2 Pro Trackpad Replacement
你所需要的
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 2 中的图像 1,1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 4 中的图像 1,1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 7 中的图像 1,1
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 8 中的图像 1,1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 9 中的图像 1,2 Lenovo Yoga 2 Pro Trackpad Replacement: 步骤 9 中的图像 2,2
    • Lift the trackpad out of the computer.
结论
6等其他人完成本指南。
Thomas Simko
于10/01/15注册
2,511 声望
创作了5篇指南
团队
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G14
5 名成员
创作了12篇指南
3条评论
Where can I buy this trackpad? Mine is done.
Jorge Suarez - 回复
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - 回复
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 9,392
