跳转到主内容
Lenovo Yoga 2 Pro Battery Replacement
你所需要的
  1. Lenovo Yoga 2 Pro Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Battery Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Battery Replacement: 步骤 4 中的图像 1,1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 Pro Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the computer.
结论
34等其他人完成本指南。
Thomas Simko
于10/01/15注册
2,511 声望
创作了5篇指南
团队
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G14
5 名成员
创作了12篇指南
13条评论
The cover does not come off “gently”- there are snaps all the way around that must be popped.
Colin Leitner - 回复
where do I buy a quality replacement battery?
I checked ebay and amazon, and there are a bunch of them. But I don’t know which one I should buy.
Thanks in advance.
Can Coin - 回复
Did you find a suitable replacement? I’m curious too - looks like prices are $60 or twice that. Worth paying more than bargain basement prices?
drwelby -
You can get a Lenovo replacement battery from Amazon. About US 46. Did it, replaced, but now machine says no battery installed! Have searched far and wide on the web, but haven’t found an answer. Lots of complaints that Lenovo and new battery don’t mix well. Still searching. BTW I bought the replacement per my comments above. It’s an exact match and they put black tap over the Lenovo name.
msalvatini - 回复
Might work with #00 Phillips driver (haven’t tried yet), but they sure look like mini Torx heads on mine (star shaped).
christian - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 94
总计 47,212
