简介
This guide will explain how to safely remove the screen from your Lenovo Yoga 2 13" laptop. It will provide a list of the tools needed as well as the easiest way to remove the screen without damaging it.
你所需要的
Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
11等其他人完成本指南。
3条评论
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
