跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will explain how to safely remove the screen from your Lenovo Yoga 2 13" laptop. It will provide a list of the tools needed as well as the easiest way to remove the screen without damaging it.
  1. Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws. Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Using the Jimmy, remove the long centerpiece covering between the hinges.
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Locate the gold wire and follow it to two clips. Remove the clips and  the clear tape securing the wire.
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Completely separate the screen from the laptop. During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
结论
10等其他人完成本指南。
Nichelle
于2015年03月11日注册
1,493 信誉积分
创作了5篇指南
团队
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G2
3 名成员
创作了6篇指南
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - 回复
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - 回复
I used laptopscreen.com.
ken - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 11
过去的30天: 71
总计 14,039
