跳转到主内容
Lenovo Yoga 2 13" Keyboard Keys Replacement
你所需要的
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 步骤 1 中的图像 1,2 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: 步骤 1 中的图像 2,2
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: 步骤 2 中的图像 1,1
    • To insert a new key, simply place and apply pressure until it snaps into place.
结论
另外一个人完成了本指南。
Nichelle
于03/11/15注册
1,550 声望
创作了5篇指南
团队
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G2
3 名成员
创作了7篇指南
4条评论
this doesn't fix a non-working electric contact, does it?
Simon - 回复
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - 回复
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - 回复
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 41
总计 17,440
