跳转到主内容
Lenovo Yoga 2 13" Battery Replacement
你所需要的
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: 步骤 4 中的图像 1,1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: 步骤 6 中的图像 1,1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
结论
12等其他人完成本指南。
Nichelle
于03/11/15注册
1,550 声望
创作了5篇指南
团队
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 65
总计 31,294
