跳转到主内容
Lenovo Yoga 2 11" Battery Replacement
你所需要的
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: 步骤 4 中的图像 1,1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 11" Battery Replacement: 步骤 5 中的图像 2,2
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: 步骤 6 中的图像 1,1
    • Once all of the wires are detached, carefully remove the battery and replace.
结论
12等其他人完成本指南。
Abbey Hickmann
于10/07/15注册
197 声望
撰写一个指南
团队
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G3
4 名成员
创作了5篇指南
4条评论
how do I remove unathorized battery error?
Manuel Durugas - 回复
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - 回复
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - 回复
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 42
总计 26,586
