跳转到主内容
Lenovo Yoga 2 11" Back Panel Replacement
你所需要的
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: 步骤 2 中的图像 1,1
    • Carefully separate back panel from laptop.
结论
3等其他人完成本指南。
Peyton Leeson
于10/01/15注册
939 声望
创作了4篇指南
团队
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G3
4 名成员
创作了5篇指南
3条评论
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - 回复
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - 回复
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 16
总计 4,712
