跳转到主内容
Lenovo Yoga 2 11" 20428 TouchPad Replacement
你所需要的
  1. Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 步骤 1 中的图像 1,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 步骤 1 中的图像 2,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 4 中的图像 1,1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 5 中的图像 2,2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 6 中的图像 1,2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 步骤 7 中的图像 1,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 步骤 7 中的图像 2,3 Lenovo Yoga 2 11" 20428 TouchPad Replacement, TouchPad: 步骤 7 中的图像 3,3
    • Remove seven 2mm Phillips head #00 screws.
  8. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 8 中的图像 1,1
    • The eighth screw at the top left is covered by a piece of silver tape. Gently peel the tape back and remove the screw.
  9. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 9 中的图像 1,1
    • There is a small black tab holding the cable for the touchpad in place. Flip this tab up using a nylon spudger to unlock the connector.
  10. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 10 中的图像 1,2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 10 中的图像 2,2
    • There is a blue plastic tab connected to the cable. Use this to gently pull the cable directly back and out of the connection point on the touchpad. If the black tab has been unlocked this should slide out without resistance.
  11. Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 11 中的图像 1,2 Lenovo Yoga 2 11" 20428 TouchPad Replacement: 步骤 11 中的图像 2,2
    • Carefully lift the touchpad up and out of the laptop. If it gets caught you may gently wiggle it as you lift to safely remove it.
    • Be careful not to pull on the touchpad if it gets stuck as this may damage the laptop and/or the touchpad.
结论
一条评论
Correction to the tools needed. The screws for the bottom panel are T5 Torx, not T4 Torx. T4 will strip the screws.
Tony Tudyk - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 530
