简介
This guide will show the step-by-step process of removing and/or replacing the speakers in the Lenovo Yoga 11” 20428. This guide can be used to replace broken speakers and remove speakers for repair. When removing your speakers, make sure to remove the battery before beginning the speaker removal process.
你所需要的
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
