简介
This guide will properly show how to remove and replace the hard drive component for a Lenovo Yoga 2 11” 20428. When removing the hard drive be sure to have the laptop turned off and the battery disconnected.
你所需要的
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
3等其他人完成本指南。
