跳转到主内容
Lenovo Yoga 2 11" 20428 Battery Replacement
你所需要的
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 5 中的图像 2,2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 6 中的图像 1,2 Lenovo Yoga 2 11" 20428 Battery Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 687
