跳转到主内容
Lenovo YOGA 730-15IWL Battery Replacement
你所需要的
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: 步骤 1 中的图像 1,1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: 步骤 2 中的图像 1,1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Max Kletskov
于04/22/20注册
40,298 声望
创作了16篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,820篇指南
2条评论
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - 回复
Check thermal paste. May be getting hot and shutting back off.
William Mobley - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 37
总计 1,351
