跳转到主内容
Lenovo Y70-70 Touch Fan Replacement
你所需要的
  1. Lenovo Y70-70 Touch Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Y70-70 Touch Fan Replacement: 步骤 2 中的图像 1,1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Y70-70 Touch Fan Replacement, Fan: 步骤 3 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Lenovo Y70-70 Touch Fan Replacement: 步骤 4 中的图像 1,1
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
结论
一条评论
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 365
