跳转到主内容
Lenovo Y520-15IKBN Display Replacement
你所需要的
  1. Lenovo Y520-15IKBN Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: 步骤 2 中的图像 1,2 Lenovo Y520-15IKBN Display Replacement: 步骤 2 中的图像 2,2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: 步骤 3 中的图像 1,1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: 步骤 4 中的图像 1,1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: 步骤 5 中的图像 1,1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: 步骤 6 中的图像 1,1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
结论
Mark A Clement
于02/15/22注册
97 声望
撰写一个指南
团队
Comm 260 Team 15 Comm 260 Team 15 的会员
Community
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 34
总计 1,202
