跳转到主内容
Lenovo Y50-70 Touch Fan Replacement
你所需要的
  1. Lenovo Y50-70 Touch Fan Replacement, Back: 步骤 1 中的图像 1,2 Lenovo Y50-70 Touch Fan Replacement, Back: 步骤 1 中的图像 2,2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: 步骤 2 中的图像 1,2 Lenovo Y50-70 Touch Fan Replacement: 步骤 2 中的图像 2,2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: 步骤 3 中的图像 1,2 Lenovo Y50-70 Touch Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: 步骤 4 中的图像 1,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 4 中的图像 2,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 4 中的图像 3,3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: 步骤 5 中的图像 1,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 5 中的图像 2,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: 步骤 6 中的图像 1,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 6 中的图像 2,3 Lenovo Y50-70 Touch Fan Replacement: 步骤 6 中的图像 3,3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: 步骤 7 中的图像 1,2 Lenovo Y50-70 Touch Fan Replacement: 步骤 7 中的图像 2,2
    • Lift the fan off of the laptop.
结论
8等其他人完成本指南。
Vivian
于01/21/15注册
351 声望
撰写一个指南
团队
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G1
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 9,308
