跳转到主内容
联想 Y50-70 Touch 电池更换
你所需要的
  1. 联想 Y50-70 Touch 电池更换, 电池: 步骤 1 中的图像 1,1
    • 确保先关闭笔记本电脑!
    • 用Phillips#1螺丝刀卸下笔记本电脑背面的所有十二个6毫米长的螺丝。
    • 施加很大的压力以防止螺丝脱落。
  2. 联想 Y50-70 Touch 电池更换: 步骤 2 中的图像 1,2 联想 Y50-70 Touch 电池更换: 步骤 2 中的图像 2,2
    • 轻轻拉下笔记本电脑的后盖。它应该很容易脱落。
  3. 联想 Y50-70 Touch 电池更换: 步骤 3 中的图像 1,2 联想 Y50-70 Touch 电池更换: 步骤 3 中的图像 2,2
    • 从笔记本上拔下电池。
    • 不要用力拉电池电缆,因为这会损坏电池与笔记本电脑的连接。
  4. 联想 Y50-70 Touch 电池更换: 步骤 4 中的图像 1,1
    • 使用菲利普斯#1螺丝刀从电池上卸下所有四个6毫米螺丝。
  5. 联想 Y50-70 Touch 电池更换: 步骤 5 中的图像 1,2 联想 Y50-70 Touch 电池更换: 步骤 5 中的图像 2,2
    • 将电池从笔记本中提出。
结论
请按逆序重组设备。
23等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
团队
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G1
5 名成员
创作了15篇指南
8条评论
Is it possible to replace the original battery with one that has a larger capacity? With this I mean if the original battery has 3700 mAh, can it be replaced by a battery with e.g. 5000 mAh?
Piet Sjonson - 回复
Perfect instructions. I took the battery out per Geek Squad instructions, put it back in but laptop is getting power as the charging light shows orange flashing like it is charging but won’t power up. Any ideas???
theaustinunplugged - 回复
I read in the instructions when I first did the replacement that it might require disconnecting once or twice at a particular charge state to allow the laptop to understand the charge level of the battery. I can’t find those instructions. Any ideas??
randy.sill - 回复
I installed the battery properly, my laptop recognizes it, and it charges perfectly fine while plugged into a power source.
The problem comes when I unplug the laptop from the power source and force it to use battery power. It runs for another ~25 seconds and then it powers off instantly with a loud "pop" noise.
I'm not sure what the problem could be. Are you able to provide me with any troubleshooting steps?
My laptop works perfectly fine with the Lenovo battery it came with 5 years ago, though its life is a lot shorter than it used to be.
Liam McLaughlin - 回复
Have you found solutions to the problem ? Pls share having the same issue
hage laji -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 79
总计 101,713
