跳转到主内容
Lenovo Y50 Touch Speakers Replacement
你所需要的
  1. Lenovo Y50 Touch Speakers Replacement, Back: 步骤 1 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement, Back: 步骤 1 中的图像 2,2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50 Touch Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement: 步骤 2 中的图像 2,2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50 Touch Speakers Replacement, Fan: 步骤 3 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement, Fan: 步骤 3 中的图像 2,2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50 Touch Speakers Replacement: 步骤 4 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 4 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 4 中的图像 3,3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50 Touch Speakers Replacement: 步骤 5 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 5 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 5 中的图像 3,3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50 Touch Speakers Replacement: 步骤 6 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 6 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 6 中的图像 3,3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50 Touch Speakers Replacement: 步骤 7 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement: 步骤 7 中的图像 2,2
    • Lift the fan off of the laptop.
  8. Lenovo Y50 Touch Speakers Replacement, Speakers: 步骤 8 中的图像 1,1
    • Locate the three speakers within the laptop.
    • The bass speaker is located near the fan's original position.
    • The side speakers are located at the upper left and right corners of the laptop.
  9. Lenovo Y50 Touch Speakers Replacement: 步骤 9 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 9 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 9 中的图像 3,3
    • Using a Philips #1 screwdriver, remove the two 2.5 mm screws securing the bass speaker.
  10. Lenovo Y50 Touch Speakers Replacement: 步骤 10 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement: 步骤 10 中的图像 2,2
    • Unplug the bass speaker from the motherboard.
  11. Lenovo Y50 Touch Speakers Replacement: 步骤 11 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 11 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 11 中的图像 3,3
    • Remove the bass speaker from the laptop.
  12. Lenovo Y50 Touch Speakers Replacement: 步骤 12 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 12 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 12 中的图像 3,3
    • Using a Philips #1 screwdriver, Remove the 2.5 mm screw holding each side speaker to the laptop.
  13. Lenovo Y50 Touch Speakers Replacement: 步骤 13 中的图像 1,2 Lenovo Y50 Touch Speakers Replacement: 步骤 13 中的图像 2,2
    • Unplug the side speakers from the motherboard.
  14. Lenovo Y50 Touch Speakers Replacement: 步骤 14 中的图像 1,3 Lenovo Y50 Touch Speakers Replacement: 步骤 14 中的图像 2,3 Lenovo Y50 Touch Speakers Replacement: 步骤 14 中的图像 3,3
    • Remove the side speakers from the laptop.
    • The red and black wires connect to the right speaker, and the blue and white wires connect to to the left speaker.
    • The side speakers are independent from the bass speaker. It is possible to remove them without having to remove the bass speaker.
结论
5等其他人完成本指南。
Andrew Tran
于01/21/15注册
820 声望
创作了2篇指南
团队
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G1
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,404
