跳转到主内容
Lenovo Y50 Touch RAM Replacement
你所需要的
  1. Lenovo Y50 Touch RAM Replacement, RAM: 步骤 1 中的图像 1,2 Lenovo Y50 Touch RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
  2. Lenovo Y50 Touch RAM Replacement: 步骤 2 中的图像 1,2 Lenovo Y50 Touch RAM Replacement: 步骤 2 中的图像 2,2
    • Gently pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: 步骤 3 中的图像 1,1
    • The RAM should be located at the indicated area inside the laptop.
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: 步骤 4 中的图像 1,2 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: 步骤 4 中的图像 2,2
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: 步骤 5 中的图像 1,3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: 步骤 5 中的图像 2,3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: 步骤 5 中的图像 3,3
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
结论
9等其他人完成本指南。
Andrew Tran
于01/21/15注册
820 声望
创作了2篇指南
团队
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G1
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 5,182
