跳转到主内容
Lenovo Y410P Speakers Replacement
你所需要的
  1. Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: 步骤 1 中的图像 2,2
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P Speakers Replacement, Removal of Hard Drive: 步骤 2 中的图像 1,2 Lenovo Y410P Speakers Replacement, Removal of Hard Drive: 步骤 2 中的图像 2,2
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P Speakers Replacement, Remove Optical Drive: 步骤 3 中的图像 1,3 Lenovo Y410P Speakers Replacement, Remove Optical Drive: 步骤 3 中的图像 2,3 Lenovo Y410P Speakers Replacement, Remove Optical Drive: 步骤 3 中的图像 3,3
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: 步骤 4 中的图像 1,2 Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: 步骤 4 中的图像 2,2
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P Speakers Replacement: 步骤 5 中的图像 1,1
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 步骤 6 中的图像 1,3 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 步骤 6 中的图像 2,3 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: 步骤 6 中的图像 3,3
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P Speakers Replacement, Removal of Motherboard: 步骤 7 中的图像 1,3 Lenovo Y410P Speakers Replacement, Removal of Motherboard: 步骤 7 中的图像 2,3 Lenovo Y410P Speakers Replacement, Removal of Motherboard: 步骤 7 中的图像 3,3
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
    My y410p can't start, overheat in some are in motherboard
    Fauzy Sadland - 回复
  8. Lenovo Y410P Speakers Replacement, Removal of Left Speaker: 步骤 8 中的图像 1,2 Lenovo Y410P Speakers Replacement, Removal of Left Speaker: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Remove two M2.0 x 3mm flathead screws on the left side (using the small flathead screwdriver).
  9. Lenovo Y410P Speakers Replacement, Removal of Right Speaker: 步骤 9 中的图像 1,2 Lenovo Y410P Speakers Replacement, Removal of Right Speaker: 步骤 9 中的图像 2,2
    • Remove two M2.0 x 3mm flathead screws on the right side (using the small flathead screwdriver).
结论
4等其他人完成本指南。
Eric Chen
于01/22/15注册
868 声望
创作了4篇指南
团队
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G21
4 名成员
创作了6篇指南
2条评论
Hello Sir,
May I look how the speaker for y410p looks like and what is the model for the speaker? Where can I find that parts? Thanks.
Aiman Nazri - 回复
Where can i find the speaker parts?
beslielim96 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 3,216
