跳转到主内容
Lenovo Y410P LCD Replacement
你所需要的
  1. Lenovo Y410P LCD Replacement, Removal of Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Y410P LCD Replacement, Removal of Bottom Panel: 步骤 1 中的图像 2,2
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P LCD Replacement, Removal of Hard Drive: 步骤 2 中的图像 1,2 Lenovo Y410P LCD Replacement, Removal of Hard Drive: 步骤 2 中的图像 2,2
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P LCD Replacement, Remove Optical Drive: 步骤 3 中的图像 1,3 Lenovo Y410P LCD Replacement, Remove Optical Drive: 步骤 3 中的图像 2,3 Lenovo Y410P LCD Replacement, Remove Optical Drive: 步骤 3 中的图像 3,3
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P LCD Replacement, Remove Keyboard and Cables: 步骤 4 中的图像 1,2 Lenovo Y410P LCD Replacement, Remove Keyboard and Cables: 步骤 4 中的图像 2,2
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P LCD Replacement: 步骤 5 中的图像 1,1
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P LCD Replacement, Removal of Palm Rest: 步骤 6 中的图像 1,3 Lenovo Y410P LCD Replacement, Removal of Palm Rest: 步骤 6 中的图像 2,3 Lenovo Y410P LCD Replacement, Removal of Palm Rest: 步骤 6 中的图像 3,3
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P LCD Replacement, Removal of Motherboard: 步骤 7 中的图像 1,3 Lenovo Y410P LCD Replacement, Removal of Motherboard: 步骤 7 中的图像 2,3 Lenovo Y410P LCD Replacement, Removal of Motherboard: 步骤 7 中的图像 3,3
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
  8. Lenovo Y410P LCD Replacement, Detach LCD assembly from main Frame: 步骤 8 中的图像 1,1
    • Detach the LCD assembly by unscrewing four M2.5x4mm Phillips Screws. (Two on each side).
    • Pull the LCD assembly away from main frame.
  9. Lenovo Y410P LCD Replacement, Unscrew Bezel (plastic frame around the LCD Screen): 步骤 9 中的图像 1,2 Lenovo Y410P LCD Replacement, Unscrew Bezel (plastic frame around the LCD Screen): 步骤 9 中的图像 2,2
    • Using a flat head screwdriver, wedge out two plastic tabs to reveal the screws.
    • One tab is in the bottom left corner and one is in the bottom right corner. Symmetrical locations.
    • Using a #0 phillips screwdriver, unscrew two silver M2.5x4mm screws.
    • These are located underneath the previously removed plastic tabs.
  10. Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 步骤 10 中的图像 1,3 Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 步骤 10 中的图像 2,3 Lenovo Y410P LCD Replacement, Remove Bezel (plastic frame): 步骤 10 中的图像 3,3
    • Unclip the latches at each bottom corner. They are located below the screws that were previously removed.
    • Place your fingers inside of the edge of the bezel. Separate the bezel by pulling it away from the back cover. Pull until one side has been lifted.
    • Use the same technique to separate all remaining sides of the bezel.
    • Starting at one corner and making your way around. Ensure the bezel is completely removed from the back cover.
    • Completely remove bezel from LCD screen and back cover.
  11. Lenovo Y410P LCD Replacement, Unscrew LCD Screen (Part 1): 步骤 11 中的图像 1,2 Lenovo Y410P LCD Replacement, Unscrew LCD Screen (Part 1): 步骤 11 中的图像 2,2
    • Unscrew the four M2.5x4mm Phillips screws. One screw is located at each corner.
  12. Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 步骤 12 中的图像 1,3 Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 步骤 12 中的图像 2,3 Lenovo Y410P LCD Replacement, Remove LCD Screen (Part 2): 步骤 12 中的图像 3,3
    • Gently lift the LCD screen and flip it over.
    • On back of the LCD screen, locate the protective tape in the bottom right corner. Peel off the tape to reveal a latch with a connector cable.
    • Flip the latch so that the connector cable can be removed. Remove the connector cable by pulling downwards.
    • The old LCD is now completely disconnected and you are ready to install a new LCD screen.
结论
8等其他人完成本指南。
Brandon
于01/22/15注册
527 声望
创作了2篇指南
团队
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G21
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 18
总计 5,686
