跳转到主内容
Lenovo Y410P Hard Drive/SSD Replacement
你所需要的
  1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: 步骤 1 中的图像 2,2
    • Remove the eight M2.5x8mm Phillips head screws that fasten the bottom cover.
    • For the Lenovo Y510P, there's another screw in the center that has to be removed.
    • Lift bottom cover off and set aside.
    • On the Lenovo Y510P, use a black spudger around the outside edge to pop loose the bottom panel.
  2. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: 步骤 2 中的图像 1,2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: 步骤 2 中的图像 2,2
    • If you intend to reuse this Hard Drive/SSD, be careful with the removal. Hard impact may result in damage.
    • First remove the two screws at the end of the Hard Drive bracket then slide the Hard Drive/SSD out of its seat.
结论
7等其他人完成本指南。
Brandon
于01/22/15注册
527 声望
创作了2篇指南
团队
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G21
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 8,474
