跳转到主内容
Lenovo X200 Memory Replacement
你所需要的
  1. Lenovo X200 Memory Replacement, Memory: 步骤 1 中的图像 1,1
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Lenovo X200 Memory Replacement: 步骤 2 中的图像 1,1
    • 2. Remove the panel to access the memory modules.
  3. Lenovo X200 Memory Replacement: 步骤 3 中的图像 1,1
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
结论
4等其他人完成本指南。
James Finch
于10/14/17注册
2,268 声望
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,143
