跳转到主内容
Lenovo X1 Carbon Laptop Keyboard Replacement
你所需要的
  1. Lenovo X1 Carbon Laptop Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • These screws can't be fully removed; they will stay attached to the back cover.
    • Loosen the seven screws from the back cover.
  2. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 2 中的图像 3,3
    • Unplug the bundled cable connector attached to the battery by pulling evenly from each side of the plug.
    • Remove the four 4mm screws from the corners of the battery.
    • Remove the 2.5mm screw from the center of the battery.
    • Remove the battery by lifting from the bottom edge and pulling towards the front edge.
  3. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the 3mm screw from the solid state drive.
    • Pull the solid state drive straight out from its connector to remove it.
  4. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 4 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 4 中的图像 2,2
    • Unplug the Local Area Network Card by prying the coaxial connectors straight up from the board.
    • Unscrew the 3mm screw from the LAN card.
    • Pull the LAN card straight out from its connector to remove it.
  5. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 5 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 5 中的图像 2,2
    • Unplug the CPU heatsink fan by flipping up the small locking flap on the ZIF connector and gently removing the cable.
  6. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 6 中的图像 2,2
    • Loosen the upper-left heat pipe screw.
    • Loosen the lower-right heat pipe screw.
    • Loosen the lower-left heat pipe screw.
    • Loosen the upper-right heat pipe screw.
    • Lift the CPU cooler straight up to remove it.
    • Thermal paste will need to be applied during reassembly.
    • Apply a small amount of thermal paste across the processor case.
  7. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 7 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 7 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 7 中的图像 3,3
    • Unscrew the 4mm screw from the audio card.
    • Pull the audio card straight back from the side of the laptop and flip it over, exposing the flat topped connector.
    • Disconnect the flat topped connector by pulling straight up from its socket.
    • Remove the audio card.
  8. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 8 中的图像 2,2
    • Unplug the laptop speakers by pulling evenly on each side of the bundled cable connector.
    • Remove the four 4mm screws from the speakers.
    • Remove the speaker wires from under the tape loops along the front of the laptop.
    • Lift the speakers and speaker wires straight up to remove them.
  9. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 9 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 9 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 9 中的图像 3,3
    • Disconnect the RJ45 ribbon cable by pulling straight up.
    • Remove the 4mm screw from the RJ45 card.
    • Move the RJ45 card slightly to the right and pull up to remove it.
  10. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 10 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 10 中的图像 2,2
    • Remove the two 2.5mm screws from the guard.
    • Pull the guard straight up to remove it.
    • Slide the bottom plastic part of the ribbon cable socket forward.
    • Disconnect the ribbon cable.
    • Lift the fingerprint reader assembly straight up to remove it.
  11. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 11 中的图像 1,1
    • Do not subject the system board to excessive shock or electrostatic discharge of any sort.
    • Remove the 4mm screw from the guard in the upper-right corner of the laptop.
  12. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 12 中的图像 1,2 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 12 中的图像 2,2
    • Lift the ribbon cable locking mechanism.
    • Disconnect the ribbon cables by pulling straight out from the socket.
    • Disconnect the ribbon cables by pulling straight up.
  13. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 13 中的图像 1,1
    • Remove the five 3mm screws from the system board.
    • Move the system board slightly to the left and pull up to remove it.
  14. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 14 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 14 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 14 中的图像 3,3
    • Remove the 4mm screw from the guard.
    • Remove the three 4mm screws from the LCD hinges.
    • Pull the antenna wires away from the hinges.
  15. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 15 中的图像 1,1
    • Lift the laptop and open the screen 90 degrees.
    • Lift the LCD unit straight up to remove it.
  16. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 16 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 16 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 16 中的图像 3,3
    • Remove the two 1.7mm screws from the bracket.
    • Remove the two 1.7mm screws from the adaptive keys panel.
    • Remove the three 2.5mm screws from the adaptive keys panel.
    • Lift the adaptive keys panel from the rear of the laptop and pull to remove it.
  17. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 17 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 17 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 17 中的图像 3,3
    • Remove the remaining ribbon cables from the back of the keyboard.
  18. Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 18 中的图像 1,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 18 中的图像 2,3 Lenovo X1 Carbon Laptop Keyboard Replacement: 步骤 18 中的图像 3,3
    • Remove the 45 Xmm screws from the back of the keyboard that are visible.
    • Remove the tape covering one of the Xmm screws and remove that screw.
    • Peel back the large ribbon cable and remove the four Xmm screws underneath it.
    • Lift the keyboard straight up to remove it.
结论
16等其他人完成本指南。
团队
Michigan Tech, Team S3-G6, Galliah Fall 2017 Michigan Tech, Team S3-G6, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S3G6
3 名成员
创作了1篇指南
9条评论
This was one heck of a difficult feat, thank you for documenting the process. It took me about one hour to disassemble and two hours to re-assemble.
Anthony Dragone - 回复
Excellent guide - many thanks for writing this. It took me about 3 hours in total as well but it’s all done now. Worst part was the 50 tiny screws holding the keyboard in place!
benjamin.s.yeomans - 回复
Hey, I did this and have some serious Wi-Fi connection issues now…Ethernet and Wi-Fi are both listed as non-operational although sometimes a network will appear in my available networks to connect to. Any idea what might have gone wrong? I took out the LAN card and reinserted it, no dice.
D Walford - 回复
You got the cables connected to the wrong little circle post on the wifi card. Swap them and it should work! happened to me drove me mad until I tried it.
derek ram -
I do have issues that seem to be the CMOS Battery.
I couldn't see that in your disassembly instructions.
I am looking everywhere for this little issue and I can not find instructions for the CMOS replacement.
Could you enlight a little where to get this information?
Juan V Bueno - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 77
过去 30 天: 278
总计 43,663
