跳转到主内容
Lenovo Vibe Z2 Pro Motherboard Replacement
你所需要的
  1. Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 步骤 1 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: 步骤 1 中的图像 2,2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 4 中的图像 2,2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: 步骤 6 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: 步骤 6 中的图像 2,2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 7 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 9 中的图像 1,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 9 中的图像 2,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 9 中的图像 3,3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 11 中的图像 1,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 11 中的图像 2,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 12 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 12 中的图像 2,2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 13 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 13 中的图像 2,2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 14 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 14 中的图像 2,2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 15 中的图像 1,2 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 16 中的图像 1,1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 17 中的图像 1,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 17 中的图像 2,3 Lenovo Vibe Z2 Pro Motherboard Replacement: 步骤 17 中的图像 3,3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 18-3, Blackwell Fall 2016 USF Tampa, Team 18-3, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 15
总计 2,052
