跳转到主内容
Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
你所需要的
  1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: 步骤 1 中的图像 1,2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: 步骤 1 中的图像 2,2
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 2 中的图像 1,2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 2 中的图像 2,2
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: 步骤 3 中的图像 3,3
    • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  4. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 4 中的图像 1,3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 4 中的图像 2,3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 4 中的图像 3,3
    • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
    • M2 × 6 mm, Phillips-head, nylok-coated (3)
  5. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the device after completing steps 1 and 2.
  6. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Hard-Disk Drive (HDD): 步骤 6 中的图像 1,1
    • Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
  7. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 7 中的图像 1,1
    • Grasp the hard drive and lift up.
  8. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 8 中的图像 1,1
    • Pull the hard drive from its port.
  9. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: 步骤 9 中的图像 1,1
    • The hard drive has been successfully taken out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 45
总计 392
