跳转到主内容
Lenovo Touch Y70-70 Motherboard Replacement
你所需要的
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 2 中的图像 1,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 2 中的图像 2,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 4 中的图像 1,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 4 中的图像 2,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 5 中的图像 1,2 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 6 中的图像 1,2 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 7 中的图像 1,2 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: 步骤 8 中的图像 1,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 8 中的图像 2,3 Lenovo Touch Y70-70 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
结论
团队
IUPUI, Team S2-G5, Harley Fall 2019 IUPUI, Team S2-G5, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S2G5
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 1,036
