跳转到主内容
Lenovo Touch Y70-70 Battery Replacement
你所需要的
  1. Lenovo Touch Y70-70 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use the Phillips #0 screwdriver to unscrew the three screws holding the battery.
  4. Lenovo Touch Y70-70 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the Blunt Tweezers from the Tool Kit to disconnect the battery connections from the motherboard.
    • Remove the battery from the device.
结论
To reassemble your device, follow the instructions on Step 3.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 14
总计 1,030
