跳转到主内容
Lenovo Thinkpad x240 Internal Battery Replacement
你所需要的
  1. Lenovo Thinkpad x240 Internal Battery  Replacement, Internal Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Device's lights should all be off.
  2. Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 2 中的图像 1,2 Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover by unscrewing the 8 0.2 mm screws holding it in place.
  3. Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 3 中的图像 2,2
    • Locate the internal battery pack and unscrew the 3 0.2 mm screws holding it in place.
  4. Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 4 中的图像 2,2
    • Unplug the connector cable that connects the internal battery pack to the laptop.
  5. Lenovo Thinkpad x240 Internal Battery  Replacement: 步骤 5 中的图像 1,1
    • Insert the new internal battery pack into the laptop.
结论
8等其他人完成本指南。
2条评论
“0.2 mm screws”? There is no such thing as 0.2mm screws! I can only assume that you’ve meant to write M2 screws though since you messed that up I’m wondering if it’s really M2 screws or if it could be M2.5 or even M3 screws instead.
This is crucial information to all those people who only have a battery dummy in their original configuration needing to figure out what screws to buy to secure the new actual internal battery inside the case.
eiion - 回复
Two supply the missing information: According to the Maintenance Manual they are three M2x4mm.
eiion - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 82
总计 15,666
