跳转到主内容
Lenovo Thinkpad x230 SSD/Hard Drive Replacement
你所需要的
视频概述
  1. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Preparations: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Locate the battery: 步骤 2 中的图像 1,1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: 步骤 3 中的图像 1,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: 步骤 3 中的图像 2,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: 步骤 3 中的图像 3,3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: 步骤 4 中的图像 1,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: 步骤 4 中的图像 2,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: 步骤 4 中的图像 3,3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Locate the hard drive enclosure: 步骤 5 中的图像 1,1
    • Locate the hard drive enclosure (marked by the red rectangle).
  6. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove enclosure: 步骤 6 中的图像 1,2 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove enclosure: 步骤 6 中的图像 2,2
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the hard drive enclosure cover.
    • The screw is designed to remain within the plastic cover. Don't worry about extracting it completely.
    • Carefully remove the hard drive enclosure cover.
  7. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: 步骤 7 中的图像 1,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: 步骤 7 中的图像 2,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: 步骤 7 中的图像 3,3
    • Gently pull the black pull tab out from above the hard drive. Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  8. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: 步骤 8 中的图像 1,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: 步骤 8 中的图像 2,3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: 步骤 8 中的图像 3,3
    • Remove the plastic rails from the old SSD/hard drive and place them on the new SSD/hard drive.
结论
21等其他人完成本指南。
Johannes
于02/25/14注册
1,061 声望
创作了3篇指南
15条评论
Hy sir
i have one question about this laptop lenovo x230 thinkpad i have internald SSD 128 i want to increase in 500GB any body can tell me
which size of ssd possible for lenovo think pad x230 and which company thanks
nisarahmed_980 - 回复
It looks to be a 2.5 in hard drive/solid state drive.
Nageek Gamer -
500GB will work fine.
John X - 回复
500 GB will work fine.
John X - 回复
Hi,
I have an lenovo thinkpad x230t convertible laptop, which I want to upgrade with a ssd what are the specifications I should be looking for in a ssd so that it would be compatible with my laptop,
Thanks in advance
adwaitgaikwad - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 100
总计 32,770
