跳转到主内容
Lenovo Thinkpad x230 Keyboard Replacement
你所需要的
  1. Lenovo Thinkpad x230 Keyboard Replacement, Preparations: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Keyboard Replacement, Locate the battery: 步骤 2 中的图像 1,1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: 步骤 3 中的图像 1,3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: 步骤 3 中的图像 2,3 Lenovo Thinkpad x230 Keyboard Replacement, Unlock the left switch: 步骤 3 中的图像 3,3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: 步骤 4 中的图像 1,3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: 步骤 4 中的图像 2,3 Lenovo Thinkpad x230 Keyboard Replacement, Remove the battery: 步骤 4 中的图像 3,3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Keyboard Replacement, remove screws: 步骤 5 中的图像 1,3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: 步骤 5 中的图像 2,3 Lenovo Thinkpad x230 Keyboard Replacement, remove screws: 步骤 5 中的图像 3,3
    • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
    • Once you have located the two screws, remove them with a small Phillips screwdriver.
  6. Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: 步骤 6 中的图像 1,3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: 步骤 6 中的图像 2,3 Lenovo Thinkpad x230 Keyboard Replacement, remove strip above keyboard: 步骤 6 中的图像 3,3
    • This step is not required.
    • Gently pull the strip out from the case.
  7. Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: 步骤 7 中的图像 1,2 Lenovo Thinkpad x230 Keyboard Replacement, pop keyboard out of the casing: 步骤 7 中的图像 2,2
    • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
  8. Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: 步骤 8 中的图像 1,2 Lenovo Thinkpad x230 Keyboard Replacement, lift keyboard: 步骤 8 中的图像 2,2
    • Carefully lift the keyboard so that you can access its connector.
  9. Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: 步骤 9 中的图像 1,2 Lenovo Thinkpad x230 Keyboard Replacement, Unplug keyboard: 步骤 9 中的图像 2,2
    • Carefully unplug the connector by pulling.
  10. Lenovo Thinkpad x230 Keyboard Replacement, done: 步骤 10 中的图像 1,1
    • You are done - the keyboard is not connected to the laptop any more and can be replaced.
结论
10等其他人完成本指南。
Johannes
于02/25/14注册
1,061 声望
创作了3篇指南
4条评论
Very good instructions. Really easy. Difficulty rather easy than moderate. Took me two minutes.
Carsten Mühlberg - 回复
How do I reinsert the strip above the keyboard? When I insert the bottom clips first I can’t get the top ones in and vice versa. Also I don’t understand the mechanism of the top clips, why do they have the shape they do?
Daan - 回复
Worked perfectly. It was easy enough that I could use a key ring screw driver
Chris Barry - 回复
Quisiera saber cómo reparar el teclado ya que está en corte y no me deja encender la laptop
Mario Sánchez Soroa - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 81
总计 10,603
