跳转到主内容
Lenovo Thinkpad X220 Keyboard Replacement
你所需要的
  1. Lenovo Thinkpad X220 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the two switches that lock the battery.
    • Then push the left switch outward into the "unlocked" position.
    • This switch will remain in the unlocked position.
  2. Lenovo Thinkpad X220 Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo Thinkpad X220 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
  3. Lenovo Thinkpad X220 Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad X220 Keyboard Replacement: 步骤 3 中的图像 2,2
    • This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
    • The 4 or 9 cell model has different ratings.
  4. Lenovo Thinkpad X220 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Put the laptop upside down.
    • Unscrew the two keyboard retention screws.
  5. Lenovo Thinkpad X220 Keyboard Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad X220 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Put the laptop back on its feet, open the lid and push the keyboard from the TrackPoint click buttons.
    • After that, pull it from the laptop assembly.
  6. Lenovo Thinkpad X220 Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo Thinkpad X220 Keyboard Replacement: 步骤 6 中的图像 2,2
    • You should now have access to the keyboard's connector.
    • Pull it gently from the grabbing tip.
  7. Lenovo Thinkpad X220 Keyboard Replacement: 步骤 7 中的图像 1,1
    • The keyboard is now totally unplugged from the laptop.
    • Here you go! Plug a new keyboard on the connector and follow the steps in the reverse order to finish your repair.
终点
9等其他人完成本指南。
alphaLONE
于07/01/11注册
927 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 58
总计 6,032
