跳转到主内容
Lenovo Thinkpad X201 Tablet RAM Replacement
你所需要的
  1. Lenovo Thinkpad X201 Tablet RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Remove the battery by sliding forward the switch here.
    • For more info on how to remove the battery, refer to battery replacement guide.
  2. Lenovo Thinkpad X201 Tablet RAM Replacement: 步骤 2 中的图像 1,1
    • The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • There are only two screws to remove as circled here.
    • The screw head used here is a JIS J00 Driver.
  3. Lenovo Thinkpad X201 Tablet RAM Replacement: 步骤 3 中的图像 1,1
    • On the edges of the RAM components, push each switch to the side.
    • The RAM chip should pop up on its own once you push each side outwards.
  4. Lenovo Thinkpad X201 Tablet RAM Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad X201 Tablet RAM Replacement: 步骤 4 中的图像 2,2
    • The RAM chip should pop up on its own once the sides are pushed outwards.
    • Gently pull on the RAM to remove.
  5. Lenovo Thinkpad X201 Tablet RAM Replacement: 步骤 5 中的图像 1,1
    • Remove the RAM from the device.
结论
2等其他人完成本指南。
Peter Gachuki
于03/26/18注册
642 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G7, Peak Spring 2018 UMass Dartmouth, Team S5-G7, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G7
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,026
