跳转到主内容
Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement
你所需要的
  1. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: 步骤 3 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: 步骤 3 中的图像 2,2
    • Remove the protective film to the left of the fan assembly.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 4 中的图像 1,3 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 4 中的图像 2,3 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 4 中的图像 3,3
    • Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 5 中的图像 1,1
    • Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 6 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: 步骤 6 中的图像 2,2
    • Carefully slide the wireless card out of the slot by pulling it to the right.
结论
另外一个人完成了本指南。
Alexander Davis
于01/23/20注册
1,114 声望
创作了7篇指南
团队
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 的会员
CPSU-WHITE-W20S1G4
3 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 44
总计 2,113
