跳转到主内容
Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement
你所需要的
  1. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: 步骤 3 中的图像 1,3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: 步骤 3 中的图像 2,3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: 步骤 3 中的图像 3,3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 5 中的图像 2,2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: 步骤 6 中的图像 1,1
    • Lift each speaker up and out from the computer.
结论
另外一个人完成了本指南。
Alexander Davis
于01/23/20注册
1,114 声望
创作了7篇指南
团队
Cal Poly, Team S1-G4, White Winter 2020 Cal Poly, Team S1-G4, White Winter 2020 的会员
CPSU-WHITE-W20S1G4
3 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 65
总计 2,346
