跳转到主内容
Lenovo Thinkpad Twist s230u Screen Replacement
你所需要的
  1. Lenovo Thinkpad Twist s230u Screen Replacement, Hard Drive: 步骤 1 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 2 中的图像 1,1
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Screen Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 8 中的图像 1,3 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 8 中的图像 2,3 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 8 中的图像 3,3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Screen Replacement, Upper Casing: 步骤 9 中的图像 1,1
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 10 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 10 中的图像 2,2
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 11 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 11 中的图像 2,2
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 12 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 12 中的图像 2,2
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
  13. Lenovo Thinkpad Twist s230u Screen Replacement, Battery: 步骤 13 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement, Battery: 步骤 13 中的图像 2,2
    • Remove the single silver screw using the Phillips #1 screwdriver.
  14. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 14 中的图像 1,1
    • Unplug the colored cables.
  15. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 15 中的图像 1,1
    • Lift the battery out of the laptop.
  16. Lenovo Thinkpad Twist s230u Screen Replacement, Screen: 步骤 16 中的图像 1,1
    • Turn laptop around and remove the two screw covers.
  17. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 17 中的图像 1,1
    • Using the Phillips #0 screwdriver remove the two screws.
  18. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 18 中的图像 1,2 Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 18 中的图像 2,2
    • Using the Phillips #1 screwdriver remove the four screws holding the screen to the laptop.
  19. Lenovo Thinkpad Twist s230u Screen Replacement: 步骤 19 中的图像 1,1
    • Disconnect the four cables and remove the screen assembly from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,386
