跳转到主内容
Lenovo Thinkpad Twist s230u Keyboard Replacement
你所需要的
  1. Lenovo Thinkpad Twist s230u Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  2. Lenovo Thinkpad Twist s230u Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  3. Lenovo Thinkpad Twist s230u Keyboard Replacement: 步骤 3 中的图像 1,1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  4. Lenovo Thinkpad Twist s230u Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo Thinkpad Twist s230u Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo Thinkpad Twist s230u Keyboard Replacement: 步骤 4 中的图像 3,3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,106
