跳转到主内容
Lenovo Thinkpad Tablet 1838 Speaker Replacement
你所需要的
  1. Lenovo Thinkpad Tablet 1838 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the middle button by putting a plastic spudger or your fingernail underneath the button and lifting up.
  2. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 2 中的图像 1,1
    • There will be two screws under the button you have removed. Use your Phillips #00 Screwdriver to remove these screws.
  3. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 3 中的图像 1,1
    • With a plastic spudger or your fingernail, find the seam where the front and back panel connect and pry open from the bottom. After making a small opening, go around the device counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 4 中的图像 1,1
    • Before you separate the panels, there is a ribbon cable connecting the LCD to the motherboard. To avoid damage of the ribbon cable, lift the panel with the LCD from right to left like opening a book.
  5. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 5 中的图像 2,2
    • This is the speaker unit, and is being held by a screw. Use a Phillips #00 Screwdriver to remove the screw indicated by the red circle in the second image.
  6. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 6 中的图像 1,2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 6 中的图像 2,2
    • The speaker is still connected to the motherboard by a little connector. Using a plastic spudger or your fingernail, pry the connector to the direction marked by the two red arrows in the second image.
  7. Lenovo Thinkpad Tablet 1838 Speaker Replacement: 步骤 7 中的图像 1,1
    • After removing the connector, you can now remove the speaker. Use your spudger or fingernail to lift the speaker up. The speaker should come out easily.
结论
Arturo Barboza
于10/26/17注册
209 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 150
