跳转到主内容
Lenovo Thinkpad Tablet 1838 Button Replacement
你所需要的
  1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: 步骤 1 中的图像 1,1
    • Remove the button on the front of the tablet that has the arrow pointing to the left .
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 2 中的图像 1,1
    • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
  3. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 3 中的图像 1,1
    • Use a plastic spudger to pry open the screen from the tablet.
    • Work around the perimeter of the tablet going counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 4 中的图像 1,1
    • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 5 中的图像 1,1
    • To peel back the ribbon connector, first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  6. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 6 中的图像 1,1
    • Remove the screw that is highlighted.
    • Use a size #00 Philips head screwdriver.
  7. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 7 中的图像 1,1
    • Remove the blue motherboard the screw was attached to.
    • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
  8. Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 8 中的图像 1,3 Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 8 中的图像 2,3 Lenovo Thinkpad Tablet 1838 Button Replacement: 步骤 8 中的图像 3,3
    • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
    • While the tabs are pushed in the buttons should pop out.
结论
Dylan Coleman
于09/21/18注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 347
