跳转到主内容
Lenovo Thinkpad T450s RAM Replacement
你所需要的
  1. Lenovo Thinkpad T450s RAM Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Thinkpad T450s RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s RAM Replacement: 步骤 2 中的图像 1,1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s RAM Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad T450s RAM Replacement: 步骤 3 中的图像 2,2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 1,3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 2,3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 3,3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s RAM Replacement: 步骤 5 中的图像 1,2 Lenovo Thinkpad T450s RAM Replacement: 步骤 5 中的图像 2,2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
  6. Lenovo Thinkpad T450s RAM Replacement, RAM: 步骤 6 中的图像 1,3 Lenovo Thinkpad T450s RAM Replacement, RAM: 步骤 6 中的图像 2,3 Lenovo Thinkpad T450s RAM Replacement, RAM: 步骤 6 中的图像 3,3
    • Pull one side of the prong that is holding the RAM in place
  7. Lenovo Thinkpad T450s RAM Replacement: 步骤 7 中的图像 1,1
    • Pull the other side prong until the RAM pops up.
  8. Lenovo Thinkpad T450s RAM Replacement: 步骤 8 中的图像 1,2 Lenovo Thinkpad T450s RAM Replacement: 步骤 8 中的图像 2,2
    • Pull the RAM out of the device
结论
另外一个人完成了本指南。
一条评论
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 44
总计 4,636
