跳转到主内容
Lenovo Thinkpad T450s Motherboard Replacement
你所需要的
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 2 中的图像 1,1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: 步骤 6 中的图像 1,2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: 步骤 6 中的图像 2,2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 8 中的图像 1,1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
结论
2等其他人完成本指南。
团队
IUPUI, Team 2-3, Harley Spring 2022 IUPUI, Team 2-3, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S2G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 42
总计 1,306
